stevesmythe
I haven't used S2P for a while but I've got a new project that needs it so I downloaded the latest version today. However, I can't get the ultrasonic sensor to work. Maybe I'm missing something obvious, but the attached photos show the Scratch blocks and the circuit board.
I put an LED on C.1 just to prove that the Picaxe and S2P generally are working. The SIG pin is connected to C.2. Without changing anything (except adding a debug command), I converted the .sb2 file to Picaxe Basic and that works OK.
I have tried the same thing on a 28X2 to no avail.
Have I missed something obvious? Quite likely due to brain fog!
PS (I know that the 5 pin header is bu**ered due to resoldering too many times but the 3 pin header works fine).
