Type 53 , BT53 Relays
1968neil
Just a quick note to save some headaches !
After laying out a pcb in RS Design Spark and having 100 produced i find the Type 53/BT53 relay is now OBSOLETE ! and no longer stocked by the usual sources.
Ive deleted the relay from the library now.
Hope this saves some headaches for others
Best Regards
Neil
Ps: does anyone have any old stock ?:rolleyes:
1968neil
There are but it looks like most have got on the "rip off" pricing structure because of availability, the original relay was around a POUND, now they seem to be up to and over Ten pounds a time.
The footprint is the problem, the spec is pretty standard.
Oh well, live and learn :(
AllyCat
It looks as if the "replacement" relays are just a standard relay on a small adapter PCB? Pin spacing appears to be normal 0.1 inch pitch, so for a small quantity couldn't you just make an adapter with a scrap of Veroboard? Or for 100 it could be worth making a small custom PCB.
