We have a 40X2 based speed controller for an electric car which also sends several variables to a serial LCD and an Openlog datalogger. We now wish to add a GPS module but the 40X2 is already very busy and we don't want to slow down its control of the critical processes it runs. The idea is to use a 20X2 to to receive the GPS sentence using Hserin, extract the relevant data then send it to the existing LCD and datalogger. In effect the serial out pins of the two picaxe chips would be in parallel.
If we use a small signal diode on the output pin of each picaxe is there any reason why this shouldn't work? Both will be sending about once per second but for the majority of time they won't coincide, there will be occasional clashes but would this cause anything worse than corrupted data?
