vectorspace
I am adding control pushbuttons to an existing project which has two 28X2's, each running the same code. Each 28X2 monitors serial data from a videoconferencing codec and sends serial commands to an audio/video/XVGA recoder to capture/stream everything whenever a call is received on the codec. There are two codecs and two recorders and they both operate the same way, one codec/recorder pair on each PICAXE. They share the power supply.
Each pushbutton is to be used to tell the corresponding 28X2 to disable or enable monitoring the serial data -- switching from 'monitoring' to 'not monitoring' to 'monitoring' etc. each time the button is pushed.
But, I want to be able to reset both 28X2's by holding both pushbuttons for a couple seconds. I have code that works fine in simulation but I want to be sure that I'm connecting the buttons in a way that will be reliable and will not cause problems of which I am ignorant. The code recognizes that the appropriate button has been pressed and then after a short delay, checks to see if the other button is also pressed. If it is, it SW resets.
Below is a schematic of the pertinent components. The placement and values are purely guesses on my part. Does the circuit look reasonable?
Happy New Year!
Happy New Year!
