StigOfTheDump
I've spent a couple of days messing about making touch sensors.
The most successful and prettiest was 4 pieces of aluminium foil sellotaped to a piece of paper with a picture of 4 buttons on the other side. I couldn't solder to the foil so I sellotaped the wires on then laminated the whole lot in one of those ID badges.
The one with the highest change was a similar construction with one large piece of foil. 2 of these were stapled together (not through the foil) with a layer of quilted toilet tissue sandwiched in between.
Another effort was some 100uF electrolytics. It didn't seem to matter which lead you used (or even both) but best results were got by touching the side of the casing rather than the end. If these were encased you would get a much smaller contact area.
Todays efforts centred around some plastic covered drawing pins (250 various colours for £1.49 at Lidl, with 160 free coloured breadboard jumper cables that unfortunately dont have the ends stripped and are curled up like a paper clip). These have a stiffish plastic cover that springs away from the drawing pin so can be tuned so that you have to press on the plastic to operate.
The applications I have in mind will need to be in a strong plastic box and be at least IP68 preferably IP69K as they will be used in a hostile environment. I am thinking the higher I can get the change, the thicker I can have the plastic box.
Has anyone else had any phenomenal successes or tragic failures with home-made sensors?
The worst of all my efforts was the one that cost 4 pence!
