Thanks. Idealy I would like a single pad as a touch sensitive area to generate a change of state when touched by a single finger, or a pair of touch pads in close proximity. Iam working on a couple of projects that could be enhanced by touch switching. Ive looked up a bit of research on the net, and capacitive touch switching would seem to be the way forward, but I haven't seen any examples of input interfacing to the Picaxe chips.Is it just a fingertip touching two contacts?
Here's a circuit, about 1/3 way down,
titled Darlington pair.
http://www.kpsec.freeuk.com/trancirc.htm
Could you explain a bit more
about what you need?
What's your project about?
e
' .---__---.
' | 0V +V |
' | SI O0 | | O
' | X4 X1 |----|>|---|<|----| --|-'
' | I3 X2 | | / \
#Picaxe 08m
#Terminal 9600
SetFreq M8
Do
Count 1, 100, w0
SerTxd( #w0, " " )
Loop
' .---__---.
' | 0V +V |
' | SI O0 | | O
' | X4 X1 |---|>|---.---------| --|-'
' | I3 X2 | _|_ | / \
' `--------' /_\
' _|_ 0V
#Picaxe 08m
SetFreq M8
Do
Count 1, 100, w0
if w0 > 1 Then
High 0
Else
Low 0
End If
Loop
Possibly, but I doubt there is anywhere in the UK which is far enough away from any UHV 50Hz mains transmissions not to pick up enough signal.So if you are stood in a field miles from any mains with this device it won't work?
Thanks for trying it which confirms I'm not in some strange magnetic field not affecting anyone else !I tried Hippy's program and circuit from post #9.
LED/resistor connected to output 0.
Works fine, when touching the diode leg.
