RonHackett
I have been experimenting with the 18M2 touch sensors, and found something interesting. If I connect a simple jumper wire to one of the touch inputs, and dip the other end of the wire into a glass of water, the touch16 result immediately drops to 0. As soon as the wire is removed from the water, the touch16 result returns to its (approximate) original value.
So, here's the question I have for all the hardware experts on the forum: Is there any possibility that this procedure will damage the touch input over time?
If not, a touch input could be used as a very simple way to sense the presence of water (for example, in a basement). Also, multiple touch inputs may be able to measure the level of water in a tank. For example, five touch inputs placed at the appropriate levels in the tank could sense whether the tank is full, 3/4-full, 1/2-full, 1/4-full, or empty.
In the real world, tanks are frequently grounded, so I added a jumper wire from ground to the water in the glass, and re-tried the same experiment. The results were exactly the same, but the same question applies: Does grounding the water increase the possibility of damaging a touch input?
I suppose the answer to both questions may be "time will tell," but if there's an obvious reason not to use this approach, I would appreciate the feedback.
Thanks… Ron
Thanks… Ron
