I am trying to use the toggle command on the second output port (after setting up with dirsc=$FF) on a 28x1...
The thing is, i'm pulling my hair out, while you can use 'toggle x' where x is 0 to 7 for the first output port, i can't see any way of using the toggle command to manipulate pins on the second output..
I need to literally toggle the output pins individually, i can't make do with just writing a byte value to the whole port in order to change the outputs...
I must be missing something basic here, i've gone through the basic manual, and searched the forum but can't find the answer.. while my 40x1 is refusing to be programmed, i wanted to harness the 16 ouptus of the 28x1, but i'm being thwarted on my attempts so far!
