laserhawk64
...and I've come up with a couple ideas.
The requirements are simple -- I want to use the PICAXE 08M that I already have, from my starter kit. I don't *have* to use the included "Proto Board" PCB, (I prefer Perf anyways!) but I'd like to keep costs to a minimum.
Here's what I've thought of so far, as options...
(1) I've always wanted an oscilloscope. OK, "always" is an exaggeration but it's been a while. Look at this and tell me how hard it would be to adapt that to a set of probe leads and use the 08M USB prog cable I have instead of that rather antique COM port connector (which is too old for my laptop!). If it's simple and cheap, I can do it. Time? I have plenty of time.
(2) I came across a link, actually it's part of the sig of a member here named Jamster. He came up with some code for a joystick mouse, and expanded it for a touch-panel mouse. (Link to thread, from Jamster's sig.) I wouldn't mind trying to do this, although it's nowhere near as practical as the first option -- my laptop already has a touchpad, and I've a spare USB one (one of the ones with a calculator function built in) for a project that is probably never going to happen (I have a lot of those!).
I'm inclined to stay away from DIY musical instruments as I'm unable to carry a tune in a large dustbin (buckets are right out!) -- I create noise, not music Also blinky LEDs are generally quite boring to me. I think if I used an *RGB* LED and got it to color-cycle, that would be nifty for all of about 0.5s.
Actually, on the subject of LEDs...
(3) Had an idea once for what is best described as a model of a "sci-fi power generator" that hasn't been built yet (notice a theme?) -- it calls for a sort of Larson Scanner like circuit, that I couldn't figure out how to build. You know those 'throbbing' or 'pulsing' LED circuits (eg Apple power light on standby or whatever)? Yeah, like that, but four LEDs in sequence... one fades in, and as it fades out, the next fades in. Also I want to generate a sort of 'electrical hum' sound (speaker and a bit of PICAXE BASIC wizardry?). Not sure if this one can be done with a single PICAXE 08M... but maybe. Maybe.
TBH I like #3 the most. But I'm sure you folks have suggestions...? I'd love to hear them!
