So I've just hooked up a brand spankin' new 28X1 on my breadboard, with a solid meter-checked 5V power supply, reset pin tied high through a 4.7k resistor, and a 330 + LED combination on Pin 7. I'm running slightly modified test code, which doesn't work properly:
<code><pre><font size=2 face='Courier'>main:
high 7
low 7
goto main </font></pre></code>
I can Run the code through PE, and the LED blinks on for about two seconds, then blinks off, and does not come back on. The results are identical with <code><pre><font size=2 face='Courier'>let pins=%11111111 </font></pre></code> , and the LED doesn't come on if I specify a different pin, so it's not a hookup problem on the output side. If I swap the <code><pre><font size=2 face='Courier'>low </font></pre></code> and <code><pre><font size=2 face='Courier'>high </font></pre></code> commands, the LED never comes on. After the code is downloaded, hard-resetting the PICAXE does not turn the LED back on. I also just tried to set the output and LED on Pin 6 and got the same results (on, off, no loop).
The download circuit (I'm using the breadboard adapter) is clearly OK, since the download does happen. Power and ground have been meter-checked. Both grounds are connected. Other than not having a reset button, this is identical to the minimal 28 pin circuit plus the LED test output.
Any ideas?
high 7
low 7
Any ideas?
