I have a unit that records minimum and maximum temperatures measured over a period since "last reset"
The setup is :-
18m2 picaxe, LCD on pin b.3, DS18B20 sensor on pin b.7, reset button on pin c.0
All works well until the temperature goes below zero. Here is the code.
Below zero the min temp always displays 0. I can see that the sensor cannot produce an integer less than 0
At the same time, the max will show a negative value. Again I can see that the signed negative integer from the sensor is > the positive values.
My somewhat fluffy ideas to overcome this is to.
1. Scale everything up for processing and back down for display. Or
2. Run a third record for all -ve measurements.
Your thoughts would be appreciated.
R.
The setup is :-
'18m2 Min/Max with reset
'Working 06/12/12
'16x2 OLED
#picaxe18M2
#No_Data
init:
symbol MINTEMP = b1
symbol MAXTEMP = b2
symbol NOWTEMP = b4
symbol LCD= b.3
symbol DEG= c.7
symbol WIPEIT= pinc.0
high c.1
serout LCD,N2400,(254,1,254,1) 'clear screen
pause 200
Main:
if WIPEIT=0 then gosub wipe ' Reset values to zero
gosub timeit 'Get current time
gosub disp1
ReadTemp DEG, NOWTEMP
Read 0, MINTEMP
Read 1, MAXTEMP
Read 2,b5:Read 3,b6:read 4,b7
Read 5,b8:read 6,b9:read 7,b10
If MINTEMP = 0 And MAXTEMP = 0 Then
MINTEMP = 255
End If
If NOWTEMP < MINTEMP Then
MINTEMP = NOWTEMP
Write 0, MINTEMP
End If
If NOWTEMP > MAXTEMP Then
MAXTEMP = NOWTEMP
Write 1, MAXTEMP
End If
gosub check 'check for neg values & display
goto main ' Doit again
timeit:
i2cslave %11010000, i2cslow, i2cbyte
readi2c 0,(b0,b1,b2,b3,b4,b5,b6)
pause 50
b11=b2/16 'hour MSD
b12=b2 & $0F 'hour LSD
b7=b1/16 'min MSD
b8=b1 & $0F 'min LSD
b9=b4/16 'day MSD
b10=b4 & $0F 'day LSD
b2=b5/16
b3=b5 & $0F
b0=b6/16:b4=b6 & $0F
check:
if NOWTEMP > 127 then neg2
serout LCD,N2400,(254,192,"Temp ",#NOWTEMP,$df,"C ")
pause 5000
serout LCD,N2400,(254,128," ")
goto checkmin
neg2:
let NOWTEMP = NOWTEMP - 128 ‘ adjust neg value
serout LCD,N2400,(254,128,"Temp -",#NOWTEMP,$df)
checkmin:
if MINTEMP > 127 then neg3 'test negative
serout LCD,N2400,(254,128,"Lo ",#MINTEMP,$df," ")
goto checkmax
neg3:
let MINTEMP = MINTEMP - 128 'adjust neg value
serout LCD,N2400,(254,128,"Lo -",#MINTEMP,$df)
checkmax:
if MAXTEMP > 127 then neg4 'test for negative
serout LCD,N2400,(254,136,"Hi ",#MAXTEMP,$df)
goto fini
neg4:
let MAXTEMP = MAXTEMP - 128 ' adjust neg value
serout LCD,N2400,(254,136,"Hi -",#MAXTEMP,$df)
fini:
serout LCD,N2400,(254,192,"Last reset ",#b5,#b6,"/",#b7,#b8)
pause 5000
wipe:
gosub timeit
write 0,0:write 1,0
write 2,b9:write 3,b10:write 4,b2
write 5,b3:write 6,b0:write 7,b4
disp1:
serout LCD,N2400,(254,128,#b11,#b12,":",#b7,#b8," ") 'H/M
serout LCD,N2400,(254,136,#b9,#b10,"/",#b2,#b3,"/",#b0,#b4)
R.
