Mad Professor
Good Day All.
I own four Sun Cobalt RaQ 550 1U Web Servers.
Each of the web servers are fitted with three cooling fans
Make: Delta
Model: FFB0412VHN.
Rated Voltage: 12Volts.
Operating Voltage Range: 4.5 to 13.2Volts.
Rated Current: 0.16Amps.
Rated Power: 1.92Watts.
Speed: 9500Rpm.
Max Air Flow: 0.447m3/min (15.79 CFm).
Noise: 41.9dB-A.
With all four units powered up, 12 fans in total it is almost impossible to hear your self think.
So I would like to be able to regulate the fan speeds based on temperature.
The 1st idea was to just use temperature sensors and control the fan speed via pwm, and that’s where I hit my 1st problem, all of the fans are the 3 wire type so the servers are monitoring if the fans are working, and by using pwm the server gets really confused about the speed of the fans and ends up shutting them down.
I could possibly fit caps across the input to the fan to try and smooth the pwm to run more like dc, but I don’t think this will work very well.
My next idea was to use stepped fixed voltages so I can have low, mid, high fan speeds, yes I could do this but I would much more like to have a linear fan speed control.
So to my question what is the best way about making linear 4.5volt to 12volt DC output that is based on temperature.
Thanks for your time.
Best Regards.
Make: Delta
Model: FFB0412VHN.
Speed: 9500Rpm.
Noise: 41.9dB-A.
Best Regards.
