Hello
I am using the following to index a table using a Picaxe 20M2.
works fine - will the table values remain when power is turned off
and only change with a new download?
Going to try to use PortB on the 20M2 to drive two TIL311's (BCD units and tens).
without intervening chip(s). Is that possible?
PS
Evidently not - guess I'll use the Picaxe 20X2. I don't understand why the unary command
BINTOBCD is not listed under Basic Commands.
PPS
Here is how I load 2 bcd characters from Picaxe 20x2 to two TI TIL311's using above code to load data.
If anyone is interested. BTW the TIL 311's are LED displays and therefore are current hogs.
Feel free to critique and offer suggestions - maybe on how to make more elegant -not interested
in saving memory - I'm using 91 bytes out of 4096 available.
Thanks
Al Hooper
#picaxe 20M2
table 0,(218,109,73,55,44,36,31,27,24,22,20,18,17,16,15,14,13,12,11,11,10)
for b0 = 0 to 20
readtable b0,b1
Sertxd("the value of b1 is ",#b1,10,13)
next b0
PS
PPS
let outpinsB = bintobcd b1
dirsb = $ff
low c.4 ;unblank TIL311's
low c.5 ;latch strobe load BCD data into 311's
high c.5 ;finished loading
pause 10000 ; wait until everyone had read display
high c.4 ;blank display
goto start
end
Thanks
Al Hooper
