parts-man73
Working on a holloween project already! I have a 110 volt AC device that I would like to switch on and off at specific times. Something like 30 seconds on, 2 minutes off. I thought of course that the PICAXE would be perfect for the timing. I have a couple 08's that I ordered by accident(instead of the 08M I wanted)
Anyway...to the point. What kind of extra hardware would be needed to connect to a DC-AC solid state relay? I was thinking about using a TIP41C transistor between the PICAXE and the relay. Is this a good idea, or will it work?
I've never learned or found a resource to learn how to select the right transistor for a peticular application. Is there any suggestions on where to go to learn about that?
Thank you,
Brian
Thank you,
Brian
