Suggested improvements, popup windows & directives
#1
1) When using Editor 6.0.9.3, (Windows 7 Pro) I have a problem where error message windows often appear behind the serial terminal window and one can't proceed without clicking OK but it is hidden. Nor can you close the terminal window because you must close the error msg window first which is behind it. Could the editor be made to remember window locations so one could set it off to top or side out of the way.
2) Can we have a directive to turn on the simulation option to simulate an I2C RTC, each time I start the environment I have to enable it in options.
Thank you in advance for your consideration.
Kevin
