I'm drawing up plans for an LED cube. I'm going to start at 3*3*3 single colour and progress from there. My aim is to reach 8*8*8 with RGB LEDs.
I'm going to multiplex the LEDs and need to expand the Picaxe output ports through the use of one or more shift drivers (depending ultimately on the size of the cube I go for).
I have read many articles about this and would like some input from you on which LED drivers to select. There are so many out there.
Do I go for SPI or I2C?
More outputs = fewer components but presumably higher cost for the chips? For example I can buy 10 74HC595s for £1. Only 8 lines each so more required, but they cascade and are dirt cheap.
So, thoughts and ideas please on which chips to buy (I have a separate thread for the technicalities of building cubes).
Many thanks,
DDJ
Many thanks,
DDJ
