Greetings folks, this seems a bit dim but I've run out of things to tweak. I am trying to download a simple test program from a winXP desktop, (using version 4.1.17 of the program editor) to a PICaxe 08M. I'm using the simple two-resistor download circuit, and I keep getting the "subscript out of range" error. I've tried running the PICaxe on four fully-charged NIMH AA batteries (which I measured at 5.5V), but after reading some other threads I'm now using three cells which gives me about 4.3V. I've tried the "test" feature under View>>Options>>Serial Port (that screen with the big green LED you click on). When the clickable LED is off (dark green) the input pin is at about 3.9V. When the LED is on (light green), the voltage increases to about 4.8V. This is incorrect but there is at least a change.
I've also tried putting an LED across the serial output pins of the PICaxe, just to see what's going on. I get a dim glow while ever the serial cable is connected, then when I attempt to send a program to the picaxe I get a brief flash from the LED then it goes dark until the evil subscript out of range error comes up.
So I'm out of ideas until I can find another PC with a serial port to test this thing on, unless anybody can suggest something else I might try.
I even tried another 08M that I'd ordered at the same time. Unless there was a dodgy batch I can't imagine they are BOTH broken from the factory, it has to be something stupid I'm missing, but what? Any suggestions from the picaxe community would be welcome at this stage. If I'm not explaining things correctly please let me know and I'll try to clarify!
