cactusface
Hi All,
I have just got myself a couple of nice 200 step stepper motors and want to put them to use. I also have a couple of the old Philips SAA1027 drivers, whcih as some of the older members may recall makes the job fairly easy, in that there are only 2 inputs Step-in and mode(Drection). The SAA1027 needs 12v+ (or more) no problem as the motors are 12v, but the problem is the inputs are not your normal logic or TTL/CMOS, they requre an HIGH of at least 7.5v and a low of 4.5v max. I did think of using transistors, BUT what about a ULN2003 which would also run at 12v using pull ups, as per the schematic below. I did think of adding an LED between the pullup and Gnd as a visual indicator??
I am open to comments good or bad, ideas or would a L293D be just as good perhaps but needs a full port to drive 2, this is only 4 bits for 2.
Regards
Mel.
Regards
Mel.
