Hi all,
I have the Astrosyn stepper motor (Y129-5) as supplied by my Picaxe supplier. I build the circuit as in manual 3 of the Picaxe manual but it does not work. When I measure the resistance between the wires I measure the following:
orange -> yellow 182 Ohm
orange -> black 99 Ohm
yellow -> black 97 Ohm
brown -> red 177 Ohm
brown -> white 92 Ohm
red -> white 92 Ohm
So, black is the centre of the coils orange and yellow and white is the centre of the coils brown and red. As this does not correspond to the drawing in the manual I think that, for unipolar use, black and white should be connected to +12V and orange, brown, red and yellow should be connected to the driver IC. But what should be the sequence of orange, brown, red and yellow?
Or is this respectively coil 1, coil 2, coil 3 and coil 4?
And should black en white indeed be connected to +12V?
Thanks,
Herman, NL
red -> white 92 Ohm
Thanks,
Herman, NL
