Hi all,
I have the wierdest thing happening with a vary simple circuit that uses a 08M.
The circuit is mains powered so I have a 1.5VA 230-24V transformer, full bridge rectifier and 1000uF smoothing cap feeding a LM7805 voltage regulator which powers the 08M.
The 08M is programmed to pulse an output pin which drives a buzzer at 24Vdc through a BC337 transistor.
When I turn the power on, the circuit takes a while for the cap to charge and then springs into life and runs well.
Here's where it gets strange. I wanted to measure the voltage across the piezo buzzer but as soon as the probe touched the solder terminal of the buzzer (24V rail) the buzzer stopped. I took the probe off and it started again (yes the meter was set to volts and not amps).
I then tried to measure other voltages (eg chip supply)...exactly the same thing. As soon as ONE probe touched a solder joint the buzzer would stop. I disconnected the probe from the meter and again same thing. This seems to happen when I touch almost any of the solder joints.
I tried a different probe...same thing. I even tried with a long piece of wire.....same thing.
What is going on here? Can it be RF?
I should also mention that the circuit only works reliably (ie, buzzer buzzes) if I remove the current limiting resistor to the base of the BC337 and replace it with a link.
