The question is; do you think this scheme would work with a 20X2,
http://www.edn.com/design/integrated-circuit-design/4335429/Microcontroller-provides-SRAM-battery-backup
And more specifically, powering a 23K256 SRAM from an output pin and retaining the data by switching to power from a CR2032 in the event of power loss.
23K256 datasheet,
http://ww1.microchip.com/downloads/en/DeviceDoc/22100F.pdf
From which,
Supply voltage 2.7V(min) — 3.6V(max)
Operating Current 10mA @ 20MHz (max)
RAM data retention voltage >= 1.2V
Standby current 4µA (/CS = VCC = 3.0V, Inputs tied to VCC or VSS)
A diode-or on V+ and the battery is a standard simple solution and this circuit seems to be the champion,
http://www.picaxeforum.co.uk/showthread.php?8353-Low-Power-Battery-Backup-Reference-Design
On the other hand, the microcontroller scheme requires no extra parts. To forstall the inevitable comment, "why don't you try it?", I managed to kill my last 20X2 and am awaiting parts from Techsupplies. In any event, I am intrigued by the ideas in the cited article, but I know nothing about the innards of the 20X2.
Baxter
23K256 datasheet,
From which,
Baxter
