I just built up the touch sensor demo board and played around a bit. I noticed that the sensing takes quite some time when using the default touch sensor configuration. This can be an issue when scanning several sensors in a row - short key presses won't get reliably recognized. Luckily the touch16 command allows changing of the confguration. A config byte of %11101000 turned out to work very well - the price is reduced resolution because the maximum count is smaller, but it still works very reliably and fast for me - I get now over 100 scans per second, so if one scans e.g. 8 buttons that would mean an overall scan rate of better than 10 Hz.
symbol TOUCHCONFIG = %11101000
touch16 [TOUCHCONFIG], C.0, w0
Wolfgang
Wolfgang
