Hi Foks. I'm using an SPE035 cheap Chinese equivalent module in conjunction with an 08M2 on a breadboard, with the pins/wiring adjusted appropriately from the 14M2 samples.
In the sample programs, the command MDEFAULT is used to restore the freq to 4mHz. Using PE5, the command gives me a syntax error.
The updated setfreq detail from the PICAXE site does not seem to mention any reason for this, where MDEFAULT is specifically referenced in para 2 of the description.
Upon switching to PE6, the command works perfectly, so I can only reason that MDEFAULT is specific to PE6 and its updated (over PE5) processing capabilities.
So I use setfreq M4 with PE5 and all is OK.
I would be interested to hear if my reasoning is correct, or whether there is a method to use MDEFAULT with PE5.
For what it's worth, I'm comfortable with PE5 and for the level of my programming, it's more than adequate. I find PE6 to be somewhat arcane and its advanced features, although no doubt suited to more skilled users, difficult to use, apart from the inordinately long loading time over PE5.
Ben Baker
Ben Baker
