Not really an everyday hobbyist project:
- Winbond WT701EM/T (Male)
- PIC16F872
- ST232C
- LM386M
All of the parts on the board are SMD, except the audio output bypass capacitor (220uF 10V electrolytic)
The Winbond chip has 56 pins - 28 downs two parallel sides. This edge is 14mm longs, so the pin pitch is 0.5mm. If you can make good UV transfers (or are willing to pay a PCB manufacturer to do it for you), then this might be possible. I'm not sure where you can buy the Winbond chip from, although the others are quite easy to source.
There is also an SMC crystal 24.576(MHz?) and what looks like a 6-pin resonator (do they exists - maybe; maybe not) - I might be mistaking it for something else, but it does say 8.000M on it, which seems suitable as a crystal/resonator speed.
Good luck and let us know if you do manage to make one!
<b><i>ylp88 </b> </i>
