I found the answer to similar inquiries in the archives, so if I missed exactly what I need, simply point where to go, with my apologies.
I want to output sound effects (mp3? .wav?) of some complexity based on certain input criteria. I have about 5 sound effects totalling 15-20s total. Size matters, I only have about 30mm width to work with. The mp3 player 'module' is way more than I need and the 20s sound recorder/playback is too big.
Is there an all-in-one sound 'module' similar to the 20s playback you offer, only smaller?
Or, ideally, I'd like some recommendations on the parts I would need to build my own (though I am a total novice).
Could I use the 18X I2C capability with an eeprom or 2 to store my sound files, and an IC to output the data as sound to an amp to a speaker? Do I even need I2C capability to do this?
Thanks.
Thanks.
