A long time ago now, I did a basic test with PWMout connected to a solid state relay.
The test failed, and I suspect the problem was due to frequency of the PWM signal coupled with the fact I was using zero-crossing switches.
If I understand them correctly, once triggered they will wait until the cross-over point to switch on, same process for switching off. If the minimum frequency of the PWM is around 4000 Hz, then presumably the SSR will never switch on.
Now I am some days away from my test bench, so a question. Has anyone tried PWMOUT with a solid state relay that is not a zero-switching device? I have some new SSRs that handle greater current but are not zero-switching - can they ordinarily handle a frequency of 4000Hz?
A follow up question - if the PWMOUT is capable of operating in the background, does it continue to work during a READTEMP command on an 18X or 08M?
