As more components are only becoming available in smd packages we need to adapt to work with these tiny packages.
A few years back i threw together a gadget to assist in the placement of smd packages, it helps out on those days where the fine motor skills are on the shaky side.
It allows me to take time with the tweezers to align the component correctly over the foot print, more important when working with the tiny IC's with fine little pins.
Then i can solder the component with a fine tipped soldering iron easy.
The back pin holds the PCB steady while the front pin holds the component in place during soldering.
With pressing the lever the front pin lifts first to allow the back pin to hold the board while the chip is positioned, fully pressing the lever lifts both pins.
