software crash upon simulation
electr
i've just recently downloaded the software onto my windows xp
i tried writing a few lines of code, and even used the example codes found in the manuals eg. parallel task code on p63 to test the simulating ability of this program
however it always comes up with the error message:
Run-time error '-2147024809 (80070057)
The parameter is incorrect. SRCVW32 lex routine: PutRegExpPropHelper - Invalid or unrecognised expression syntax
even with something as simple as
high B.1
wait 1
low B.1
is erroneous
i've read about the possible problems with language settings, but mine is set to english on both the program and computer
any help to the problem is appreciated
Welcome to the forums.
You have a non-standard version of SRCVW4.DLL somewhere lurking within your windows folders (often in /system32). This may have come from a different software installation, as it is not only PE5 that uses this file.
Delete all instances of this file manually and then reinstall PE. This should resolve the issue.
electr
tried deleting all the SRCVW4.DLL, then reinstalling it, but the same thing happens
so does uninstalling, rebooting then reinstalling it again
as an extra info, i've got v4.0.1.2 of the SRCVW4.DLL in the /system32 folder
