I'm managing a large program which spans multiple slots on my 28x2. It seems that when I use background receive mode (i.e. hsersetup B14400_8, %00111) the hserptr gets corrupted when I switch between slots. The code works fine and the pointer is accurate when I don't switch. And the routines I've moved to another slot also worked fine with background receive when everything is in slot 0 . When run from the other slot the routines also work fine, but somehow the switching back and forth affects the pointer.
Is this a confirmed issue?
Is there a workaround?
