sleep/underclocking question
gengis
It is my understanding from reading the archives, that if I "poke $8F,%01000000" I slow the clock from 4 to 1 MHZ and this saves a bit of power, and I can expect nap, pause and sleep to be multiplied by a factor of four?
first part of my 14M program
b5=0 'reset picture count
low 1 'Pin 12 shutter low
pause 1000 'allow caps time to charge
poke $8F,%01000000 'Set clock to 1 MHz
pause 5 'allow clock to stabilize
goto start
I went in and divided all my pause settings by 4 and the program behaves the same as it did before the clock speed change. BUT my sleep command is about 4 times too short! Went from four minutes to one minute.
I tweaked it in software and multiplied the variable controlling the sleep by 4 times and it is back to normal.
My sleep variable is set by an adc so I suppose the adc could also be affected by timing, is that possible?
PAUSE will be affected but SLEEP and NAP have their timing controlled by the 31kHz oscillator so will not be affected.
gengis
I was debating whether to amend my original post because I did find the statement in the archives about sleep and nap NOT BEING effected by clock speed - what I'm experiencing is it is speeding up by a factor of ~four. So it is, or seems to be, affecting it, but not in the way I originally expected it to.
That does seem odd. Maybe try a simple loop with a SLEEP, a TOGGLE for a LED and nothing else to see what effect switching to low speed before entering the loop has ?
