When stepping through a 20X2 simulation that uses "IF variable BIT value SET THEN" where variable and value are both byte variables, I was surprised that it needs 4 steps to process the IF statement. Is this normal and does it reflect that it takes a long time to process in silicon?
The same simulation has a quite complex statement "IF ang<messtart OR ang>mesend THEN" that only takes one step in the simulator.
