Hi all,
Just received my new M2 picaxe chips.
I had some 08 and 08M chips laying around so I decided to do some tests.
One of these tests is a simple speed test.
setfreq [k31, k250, k500, m1, m2, m4, m8, m16, m32]
output 4
toggle 4
the picaxe is powered with 4.5 vDC using a regulated powersupply.
on pin4 I connect a frequency counter.
for the 08 I run without the setfreq
for the 08M I run the setfreq with m04 and m08
for the 08M2 I tried all speed settings.
these are my findings:
08 @ 4MHz : 918 Hz
08M @ 4 MHz : 861 Hz
08M @ 8 MHz : 1724 Hz
08M2 @ 31 KHz : 3,5 Hz
08M2 @ 250 KHz : 28 Hz
08M2 @ 500 KHz : 55 Hz
08M2 @ 1 MHz : 111 Hz
08M2 @ 2 MHz : 221 Hz
08M2 @ 4 MHz : 442 Hz
08M2 @ 8 MHz : 885 Hz
08M2 @ 16 MHz : 1770 Hz
08M2 @ 32 MHz : 3540 Hz
If you compare the 4MHz values of the 08, 08M and 08M2 you notice the speeds are : 918, 861 and 442
It looks like the speed of the newer picaxe chips are slower.
Anyone an idea why this is?
could it be that this is due to multitasking capabilities of the 08M2?
Or perhaps some other stuff that is happening on the background? (maybe stuff that can be disabled?)
Lazarus
output 4
toggle 4
08 @ 4MHz : 918 Hz
Lazarus
