Hi all,
I am building a dual thermometer circuit using precision NTC thermistors with parallel and series resistors (thus creating in effect a potential divider with low power dissipation through the NTC). Clearly using adcconfig to set Vref-, Vref+ to external pins with preset voltages will give me increased precision over a defined range.
However, when the temperatures experienced by the NTC travel outside the associated Vref- to Vref+ boundaries, I want to be able to set Vref+ back to 5v so that I can still read a value and then using a different scaling routine, deliver sensible values outside the 'precision' range.
Now, is it ok to repeatedly swap back and forth with the reference pins by issuing adcconfig commands without risking damage to the ADCs or any internal PIC circuitry?
Sorry if this appears a simple question , just me being over cautious as ever!
Regards
Eclectica
Regards
Eclectica
