Signal Generator
Sorry for I need to generator a square signal for a wireless power experiment. Mit didnt some work with resondence inductance. Basic they send out a wave ringing at a spefic freg. The secondary coil received that, but had a cap. to form a LC circuit so it to would ring to that freq.
MPep
As Manuka says : this is a PICAXE! forum.
Suggest you post your electronic questions here http://www.electro-tech-online.com/
Also, I don't understand your question. The only difference is the fact that one has a DC component. Simple to remove. Use a capacitor to block the DC.
I bet the square wave comes out of a PICAXE (soon ;) ).
How about reading up on Op-Amps and a dual rail supply?
That should get you started.
