Hi all,
First of all, I'm looking to build a small altitude datalogger to attach to a model rocket. I'm using the Motorola MPX4115 Pressure Sensor.
I've got the system worked out I reckon, apart from the signal conditioning.
Moving from 0ft to around 5000ft, the output voltage of the MPX4115 goes from ~4.8v to ~3.6. I don't have the unit yet so I can't test this, but the datasheet says this is about the output I can be expecting.
Looking at this site here:
http://www.geocities.com/SiliconValley/Orchard/6633/altimeter.html
They are using a MAX407 to condition the signal before feeding it into a 12bit ADC. The ADC is a MAX187 and I will be using the internal reference, giving it a maximum input voltage of 4.096v.
In short, the signal:
- needs to be dropped by around 3.6v to make the range 0.0v - 1.2v.
- multipled by around 3 to scale it up to use the full input range of the ADC.
Just to make this relevant to this forum, the ADC output will be fed into a PICAXE 18X (using bit-banging as the ADC uses an SPI interface).
So that 3.6v - 4.8v signal needs to be scaled so it uses the whole 0v - 4.096v of the ADC input.
What I'd like to know is how I should use the MAX407 (or any other components) to correctly condition the signal before it is fed into the ADC.
I can see the circuit diagram on that website, but I do not understand it, so any help with that would be appreciated.
Thanks a lot,
Jon
Thanks a lot,
Jon
