Show wire voltage & current options lock-up VSM?
dartec
Hi, I have ticked 'show wire voltage by colour' and 'show wire current by arrow' in animation settings. When run simulation it locks-up and I get 'not responding' mesage so have to close VSM. Does this work as it is 'ISIS Lite' or do I have a settings issue?
Regards.
dartec
PS: I have the full version of Proteus (ISIS Pro 7) that I use for circuit design/experimentation (pure hobby only - not expert!), which I upgraded from a Lite versiona few years ago, in fact must update my USC as I have let it run out.
The connecrtor CT1 is not really a real component 'SPICE model', and so ISIS gets a bit confused on how to source current in and out of it and hence the issue with the wire colours here. We will look into this, but if you simply exclude the connector from the simulation (right click>properties>exclude from simulation check box) the example will run as expected.
