I'm seeing a intermittent problem/fault with serial reception of sms's from a GSM module. On some occassions the sms come through clear. Other times its corrupted with random characters of the type you see when you serial out to a LCD with the wrong baud speed/mode.
At the monent the serial line between the gsm module and the picaxe is floating, tied neither high nor low. Could this be the cause of the problem?
I am serialing from the module at T2400_8.
