BillyGreen1973
Just a quick pointer,
Today I was playing with the Axe401, with a 24LC512 EEPROM in the on board socket (4k7 R's are in place), trying different #Slot programs.
I was having trouble using slot 4 (EEPROM), then I realised I needed to remove the H4 LED Enabled jumper to allow correct I2C comms.
Everything then worked fine once this is removed. It does say in the axe401.pdf about the LED...
"this can adversely affect using this pin for another purpose e.g. as a touch sensor input."
what it doesn't mention is that it DOES adversely affect I2C comms.
While this may be obvious to most, it can be quite frustrating for a beginer. So to use the I2C on the axe401 REMOVE H4 jumper!
