Hi Technical, Hippy,etc
I have several small projects where it would be very useful to use serial communications as well as the servo commands at the same time, or atleast suspend the servo operations until the serial op's have finished.
For example - retrieving servo movement commands from a VDrive or other system and then sending them out to the servo(s)
If I could turn off the servo's for a moment and then re-initialise them witoug changing the position data that would be great as well.
Do you have any suggestions or an idea if the PicAxe code will ever support this.
Many thanks
Dave
Many thanks
Dave
