hi all
i am using a 40X2 picaxe and i would use the serin /serout command but there is some difficults
the manual say:
SERIN [timeout,address], pin,baudmode,{#}variable,{#}variable
and
Pin is a variable/constant which specifies the i/o pin to use.
for that i try A.0 to A.7 and B.0 to B.7 , C.0 to C.7 and D.0 to D.7
not all pins names are accepted by the compiler and nowhere in the manual i found explanations about this
i am sure that some senior member get the answer
thanks by advance
jyb
the manual say:
and
thanks by advance
jyb
