Minifig666
I was wondering what circuit I would need to send serial data between two PICAXE chips? I see no mention of it in the manuals. Basically I wish to use an 08M as a sort of shift register connected to an 28X1. Also is it possible to use the Serial in/out pins and the SERTXD/RXD commands. Would I still need the download resistors in place if using the serial I/O pins?
