masterchief1517
Hey everybody. I picked up one of Anderson's now-outdated LCD #118 serial kits a couple years ago to hopefully try to get my LCD (YJ-162A [Presumed to be standard, 16x2]) to work with my picaxe. Plenty of odd issues kept me from doing so back then. Just recently, I dug it back out and started going through everything and tried to get it to work, but it still doesn't.
When I give it 5V, then first row on the LCD is solid blocks, the bottom is blank, and nothing else happens even after letting it see for a few seconds and trying to use the reset. My guess is that the screen isn't initializing properly?
I also did a quick test on the using the pin 8-to-ground testing mode and I used the 5V test LED. The LED had no activity at all.
I'd thank you kindly for any help someone could offer.
Jonathan S.
Jonathan S.
