Serial LCD Simulation Display Problems
dartec
I have used PICAXE before (pure hobby) and was hooked again when I saw the Proteus VSM, duely bought, better to damage virtual circuit than physical.
However, this is my 3rd post in as many days and I appreciate the time from the forum. But I have been testing the serial lcd and the displays is not as expected.
My programme is simple:
serout 7,N2400,("Hello")
pause 500
serout 7,N2400,(254,128)
pause 500
serout 7,N2400,(" ")
pause 500
This works in the Programme Editor but when run in VSM I get random chars, please what have I not done or missed?
Regards
Ray
Have a look at the VSM sample file \PICAXE\Products\AXE110 datalogger.dsn
It has an example of a working AXE033 circuit. Note that in simulation you may need to use T2400 rather than N2400, this is a limitation of the model.
dartec
Sorry for delay in logging on.
SilentScreamer: not sure how to post circuit.
Technical; tried T2400 instead and it appears to work. Forgot about datalogger circuit so will check that too.
Many thanks to both of you for your replies.
