I am working out ways to network picaxes together. I'm currently exploring what might be needed to use hardware handshaking, ie. a 'clear to send' line. This line would be set high by any picaxe on the network to prevent others from using serout.
This means that each picaxe would need to have an output connected to the line and be able to check status of the line with an inputh. In order to do this, I'm guessing I will need to diode each output to a common point which is then connected to each input. Would there need to be any current limiting resistors? Is there a more elegant way to do this?
thanks, Arnie
thanks, Arnie
