Hello all, i am planning to build a wireless servo controller for a project.
I plan to do this by
Picaxe -> 433mhz transmitter---Reciever -> Picaxe -> Servos
In the manual it says 'Note that the overhead processing time required for processing
the servo commands every 20ms causes the other commands to be slightly
extended i.e. a pause command will take slightly longer than expected. The servo
pulses are also temporarily disabled during timing sensitive serin, serout, sertxd
and debug commands.'
Does this mean the servos would lose position when a command is recieved on the serin pin?
If so what work arounds are there? i would like to avoid purchasing the 21 servo driver board if possible.
Cheers
Cheers
