ffor a project I must measure the temperature and the air humidity.
For it I have got myself the HYT 221.
https://www.ist-usadivision.com/objects/media/data-sheets/product/humidity-module/HYT-221.pdf
With an Arduino and this programme I can select the values / register
#include <Wire.h>
void setup() {
#define HYT_ADDR 0x28 // I2C address of the HYT 221, 271, 371 and most likely the rest of the family
Wire.begin(); // Join I2c Bus as master
pinMode(13, OUTPUT); // Set pin 13 to output for status LED
// I2C Pins on the Arduino Uno are A4 for SDA and A5 for SCL
Serial.begin(9600); // Start serial communication for serial console output
void loop() {
double humidity;
double temperature;
Wire.beginTransmission(HYT_ADDR); // Begin transmission with given device on I2C bus
Wire.requestFrom(HYT_ADDR, 4); // Request 4 bytes
// Read the bytes if they are available
// The first two bytes are humidity the last two are temperature
if(Wire.available() == 4) {
int b1 = Wire.read();
int b2 = Wire.read();
int b3 = Wire.read();
int b4 = Wire.read();
Wire.endTransmission(); // End transmission and release I2C bus
// combine humidity bytes and calculate humidity
int rawHumidity = b1 << 8 | b2;
// compound bitwise to get 14 bit measurement first two bits
// are status/stall bit (see intro text)
rawHumidity = (rawHumidity &= 0x3FFF);
humidity = 100.0 / pow(2,14) * rawHumidity;
// combine temperature bytes and calculate temperature
b4 = (b4 >> 2); // Mask away 2 least significant bits see HYT 221 doc
int rawTemperature = b3 << 6 | b4;
temperature = 165.0 / pow(2,14) * rawTemperature - 40;
Serial.print(humidity);
Serial.print("% - Temperature: ");
Serial.println(temperature);
else {
Serial.println("Not enough bytes available on wire.");
blinkWait();
void blinkWait() {
digitalWrite(13, HIGH);
delay(1000);
digitalWrite(13, LOW);
delay(1000);
Now I try to select in vain the sensor with 20x2 about I2C and get no reasonable values.
Byte 0 is 29 and the following three bytes 255.
I have pulled SDA and SCL with 4K7 on 5 V. Has developed the opposition also sometimes. It Changing to itself, however, nothing.
SCL on B.7
SDA on B.5
So in the kind I have tested it:
start:
let b8 = 4
hi2csetup i2cmaster, $28, i2cslow, i2cbyte
; i2cslave $28,i2cfast, i2cbyte
writei2c 0,(b8)
pause 10
readi2c 0,(b0,b1,b2,b3)
debug
goto start
Can somebody help me there?
Wolfgang
#include <Wire.h>
void setup() {
void loop() {
double humidity;
double temperature;
else {
blinkWait();
void blinkWait() {
delay(1000);
delay(1000);
SCL on B.7
SDA on B.5
start:
let b8 = 4
writei2c 0,(b8)
pause 10
debug
goto start
Wolfgang
