stocky6409
I'll post a schematic once I have adjust various sections to keep some members happy
I have a 5v 40mA solar cell charging 3 x AA nicads via a Schottky diode with the output via an LDO powering an 08M & Xbee module.
I'm using the 08m to enable/disable the xbee "sleep" pin so that i can sleep the xbee for periods longer than the maximum internal "cyclic" sleep period of 268sec.
I want to have the xbee send updates every (approx) 15 minutes during daylight and hourly during darkness.
I could use an LDR to sense the light levels BUT that would mean i have to expose another sensor in what is an environmentally harsh location. I thought if i could sense the output from the solar cell that would be a better solution.
Any suggestions? A simple transistor with its base fed via a suitable resistor would seem logical - or maybe a small fet - pulling a pin low on the picaxe? Then that can be acted on in code to select one of two timing loops (day/night)
Stocky
Stocky
