premelec,
I love the idea of using a whistle as an alarm. Nothing like an irritating noise to alert you that a dangerous condition exists.
parts-man73,
If you wanted to do something different and highly rewarding with a picaxe, why not get involved in the emerging field of vegetable oil fueled diesel engine controls.
Working in a salvage yard you are in a prime position to be able to get a vehicle with a diesel engine at a better price than most.
If you are successful, you can reap the benefit of being able to virtually drive your car for free. Not a small accomplishment in these days of sluggish economys, low competitive wages and high priced fuels.
My son bought a well known conversion kit for his 95 Suburban. Just one of the restaurants in his area would be able to freely give him 140 gallons of vegetable oil per week. That is like getting over $300 of free fuel per week.
As the old saying goes, A penny saved is a penny earned.
Nothing like getting a $300/week pay raise. The added benefit is that the increased earnings are NOT taxed.
The kit came with a DPDT center off switch which controls two direct acting, three way solenoid valves which determine the three operating modes.
Run on Diesel (center off)
Run on Veg oil
Purge Veg oil
It is up to the operator to monitor engine temps and throw the switch to Veg oil when the engine comes up to operating temperature. The operator must remember to throw the switch to Purge a short time before reaching the destination and finally return the switch to Diesel when finished.
Forgetting to switch to veg oil after warmup wastes diesel fuel.
Forgetting to purge can result in the fuel system clogging up with congealing veg oil in cold weather.
Forgetting to return the switch to Diesel can result in diesel fuel being transferred to the veg oil tank.
All of the above is likely to occur if his wife drives the car or he gets preoccupied with another matter while driving.
I had thought it would be an ideal task for a micro to manage the system. PICAXE could monitor engine temps via thermistors and put the system into veg oil after warm up.
It could sense when the operator turned the ignition key off and begin the purge routine and finally killing the fuel shut off valve after the system was purged.
Although the engine would continue running for a short time after shutoff, the vehicle would not be going anywhere with a locked steering column. Nor would it get far with the limited time remaining on purge before automatic shutoff.
The advantages of having a micro handling the process would be optimum use of veg oil, minimum use of diesel fuel and always having purged fuel lines for the next start up.
You could have one override switch on the dashboard for forcing the system into diesel.
A DPDT switch could kill the power to PICAXE and reconnect the fuel shut off solenoid to the vehicular wiring system.
The two issues I have not discussed is that of the heat content of veg oil and the effects of lowering the viscosity by having to pre-heat the veg oil to use in a veg oil run diesel. Also, the effects of running hot oil in a fuel system designed for ambient air temp oil.
If you are interested, I can start another post to explore the benefits of having PICAXE also control the amount of heat gain of the veg oil.
Edited by - desulfator on 16/03/2006 16:17:04
