Hi guys,
I've been using Picaxe for a while now, but I'm fairly new to the RX/TX wireless communications stuff.
What I want to do is, send 2 strings of text from Picaxe 1 and display the text on a 2x16 character serial LCD connected to Picaxe 2, wirelessly.
I would normally send commands directly to the LCD like this:
serout 4, T2400,(254,128,"TOP LINE ") '1st line of LCD
serout 4, T2400,(254,192,"BOTTOM LINE ") '2nd line of LCD
How can I send these commands to the LCD via the TX/RX modules? Please keep in mind that I want a string of text to appear on the first line and second line separately.
Block diagram:
Picaxe 1 > TX module ..(((wireless))).. RX module > Picaxe 2 > 2x16SerialLCD
I will also be wanting some relatively simple code to deal with packet loss, noise/garbage from other sources etc., so if anyone can come up with some sample code for me, it would greatly appreciated!
My hardware:
- Picaxe 18M2 (sending end)
- Picaxe 18X (receiving end)
- 2x16 character serial LCD
- 433MHz Data Transceiver (TX/RX)
http://www.altronics.com.au/index.asp?area=item&id=Z6900
http://www.altronics.com.au/index.asp?area=item&id=Z6905
Many thanks in advance
Block diagram:
My hardware:
