Ok, here is the problem. A squirrel (or squirrels) is using my roof as a path to go from a tree in the front of the house to another tree in the rear. Because of the nature of squirrel claws, this is very destructive to the shingles. Cutting down the trees is not an option. There is a low tech questionable, temporary solution such as spreading cayenne pepper or one of the fox urine products, but the results seem to be spotty at best. Then there is motion detction. I have several cheap Harbor Freight battery powered PIR nightlights and thought to place them strategically along the path. I abandoned this idea when I discovered that tree squirrels are diurnal and the nightlights won't work in daylight. However, this product seems to work in daylight,
http://www.amazon.com/Driveway-Patrol-Sensor-Receiver-Kit/dp/B0000645RH/ref=sr_1_1?s=electronics&ie=UTF8&qid=1344799233&sr=1-1
My thought here was to mount the detector and alert module together and point it along the path. Then when the squirrel is detected, the alert triggers and scares it away (maybe). I also have a bunch of old 08m parts, but I am not sure the DIY approach is as cost effective as as the Driveway Patrol when you factor in the cost of the sensor and piezo buzzer.
Any thoughts on this problem are most welcome ...
Baxter
Baxter
